Posted By JeffD on 18 Jul 2010 08:10 PM
awhite,
When using metal framing in general one should plan out where to use solid wood blocking to ensure proper fastening of decorative trim, window treatments, appliances, cabinets, door casings, control boxes, lighting fixtures, railings etc. One example of this is to install a continuous wood furring strip at the base of the wall to allow the base boards to be installed with a brad nailer. Using metal furring strips at the base of the wall is acceptable as well, but one would have to glue the base boards to the wall.
Cabinets should be anchored to solid wood blocking that is glued and screwed to the metal SIP wall between the furring channels and at the appropriate heights.
Metal SIPs usually have a factory painted finish so reaction to bare metal like copper piping is not a problem.
On the otherhand we try to avoid termite food as blocking, we never use for base, door casings, window bucks, etc. finish nailers will shoot intoand bite- up to 20 ga. steel, brad nailers will work too. 18 ga. flat strap can be used for kitchen cabinets, stair rail backing and grab bar installations and is much easier to install than wood blocking. we do still use wood for interior stairs and upper floor decking to steel joist systems.
I have not seen an interaction occur with steel/copper, in fact plumbers use steel strap. copper is rarely used CPVC is the most common pipe
