Posted By SimonD on 06 Oct 2011 12:31 PM
Permatherms/Precision Foam Fabricators joint is very loose and the foam cores can bottom out and meet because the sheet metal is flexible and easily flexes out of the way because of it's flat profile. That makes the panel hard to seal and maintain it's weather-tightness especially on a roof condition where one panel will shear past another and break it's seal if you stand on the roof near the lock on longer spans.
Simon;
my gosh from the frying pan into the fire now implying that both manufacturers shear at the joint?
I have installed many from both manufacturers and have never had that occur?
Where have you seen this happen?
