Posted By NRT.Rob on 28 May 2012 04:30 PM
Extruded plates will beat the pants off of nearly any lightweight plate out there... no lightweight can do a tubing groove with as good of a contact. it's as big of a difference as no plates vs lightweight plates again.
Warmboard aluminum will outperform concrete as well with identical flooring assemblies above... it's near 100% coverage and on top, no extra insulation. I bet with the labor savings it's probably similar in cost too, and faster response. I'm not saying concrete is BAD, I'm just saying, it's hardly the only game in town and you're jumping through some pretty silly hoops to make it work on what is at least partially superstition based on your responses. If you're doing a slab on grade home, obviously put it in concrete. If you need some weird custom framing detail, maybe not.
extruded plates also hold pipe so it can't move, so the "thermal stresses" are moot. no argument that plates in a joist bay won't be as good as concrete on top of a subfloor, of course. but I design very little but very low temperature systems, and we use both plateless and plated radiant on a regular basis when it makes sense to do so. which is a lot of the time, when you run the numbers. I have at least a couple dozen plateless systems out there at 110-115 degree design temps because the loads allowed for it. My shop, on the other hand, is 90 degree max warmboard with wood on top.
Currently my main floor is tubing in between 2x2s @ 12"oc and in gypcrete and I too run 90F max and I have bamboo T&G on top. BSMT is a couple of old cast rads and so is the 2nd fl. No heat needed on the 3rd but my Fujitsu is there for cooling.
My belief in concrete is not based on superstition but my experience and yes, it does come from the Europeans whom I have studied under and gone to Germany to work with a bit. They did invent the modern radiant heating methods, Warmboard and aluminum plates excepted, and it seems, just about every improvement in hydronic heating.
I have done aluminum plates and warmboard, and i know it can work well, but I prefer the density, sound insulation and fire protection of cement. I feel that I have more freedom of loop layout when I can staple down to a subfloor without concern for the limitations of the plates.
To each they own, I guess.
