Problem with your heat pump? Start here.......
Last Post 23 Mar 2021 02:15 PM by Robert Vear. 26 Replies.
ICFHybridUser is Offline
23 Feb 2014 10:33 PM
Carl Odle, Homeowner with common GEO problem??
OMG. "Start Here..." means read this FIRST and then start a new thread.....
cgmcleodUser is Offline
25 Feb 2021 06:34 AM
I am having a problem with my Geothermal Heat Pump 4 Ton?? it is making a clunking sound.
25 Feb 2021 06:36 AM
I have a 4 ton Heat Pump Geosmart, I am having a problem noise. the noise begins when the Heat is beginning into the force air system then I hear a clunk at the end. Over time this clunk has become louder. what is it and what should I do about it.
Robert VearUser is Offline
Iron mud in well pipes.
Is there a process to clean the iron mud out of the pipes of an open loop well system?
I clean the coils 2x a year but the pipes outside of the unit have some buildup.
When moving some of the pipes due to other needs, the service found that the pipes had a significant amount of iron mud in them that you could scoop out with your finger.
How can I clean this out?
Thanks!
People Online People Online: Visitors Visitors: 207 Members Members: 0 Total Total: 207
