There are some simple rules of thumb. One from Europe is that 1m2 of panel area will give 50% of the DHW for one person annually. Since we typically use more hot water then they do and since we don't buy panels that way, you could size for 2- 4x8' panels (3m2 each) will do for 4-5 people. Your area is much like mine and this is the standard installation, barring doing a proper simulation (which is quite easy). Since you have a roof full of PV, you could retrofit some of those panels to get 40-50% of your annual DHW with a PVT panel and not lose any PV output. 2kw of PVT will do. Also, instead of an electric boiler, a heat pump would cost less to run. http://analogenergy.com/
