I live in a wood frame house built circa 1940 (coastal California). It was pouring rain this morning and I got a call at work from my daughter that there was water coming through the ceiling. I went home and opened up the attic and found a pretty good leak from the area around the valley. For now, I put a container under it, and am running a fan to dry it out.
But I realize I need a new roof. I always figured that when I do replace the roof, I would do it right and insulate it and extend the overhangs. Currently there is no insulation and no overhangs. The house was originally built as one story with a 12:12 roof. In 1952, the attic was finished to create some additional bedrooms. The footprint is about 1000 sq. ft. Gyp board was applied to the bottom of the roof rafters in the finished area of the attic. The 2x4 roof rafters sit on the exterior walls with no overhang and there is 1x decking, not skipped.
I would like some opinions about how to go about re-roofing. I considered SIPS, but there would be no access for a crane, so getting them on the roof my pose a problem. And there are 4 valleys and 3 skylights to work around.
Another option would be to remove the existing shingles and have foam insulation injected into each bay and spray the bottom of the roof in the areas that are just attic. That would solve the problem of insulation, but not extending the overhangs.
I could also apply plywood on top of the existing decking, then install stringers that would cantilever past the exterior walls to create the overhang. Rigid insulation would go between the 2x stringers and plywood over the top. I would top it all off with heavy composition shingles.
Most of the roof is not vented, since they applied gyp board to the bottom of the roof rafters and the remaining spaces behind the knee walls were not vented. This doesn't seem to be a problem since there is no insulation and the indoor humidity is not an issue.
Any thoughts on the subject? Or any other suggestions for achieving a similar end result?
I appreciate all the ideas that people take the time and effort to post on this forum. The combined experience of the members is phenomenal.
