vertical ICF?
Last Post 03 May 2007 09:20 AM by Alton. 3 Replies.
mark pecoraUser is Offline
01 May 2007 10:48 PM
Has anyone one had any experience with an ICF system called "vertical ICF"?   I found a website for a company (tfsystem.com) and spoke to a builder who apparently uses it.  They state that placing the forms upright (up to 12 feet high?) results in less seams and joints.  Anyone have any insight?
Thanks, Mark Pecora
James EggertUser is Offline
02 May 2007 08:40 AM
Do a search and then repost questions! Some like them, some don't, check what has been discussed and then you'll have a better idea.
djschrallUser is Offline
03 May 2007 03:19 AM
Mark,
I recently used these vertical ICFs on part of a new garage. I have also worked with a horizontally laid ICF from Reward. I feel that the verical is harder to work with and is somewhat more expensive than Reward. The one main advantage of the verticals are that if you drop a tool down into the cavity, you can theoretically raise one of the panels to get at the tool.
I am also researching other ICF manufacturers to find out which ones are easiest to use vs. price.
Dave
Mark Pecora,
I have used a vertical system called ICF Tilt UP to build a storm shelter in Auburn Alabama. Since the forms were assembled at the shop, they went up fast. See www.icftiltup.com The homeowner and I were very pleased with the results.
People Online People Online: Visitors Visitors: 118 Members Members: 0 Total Total: 118
