Considering 4" block for a 4.5' x 6.5' (interior) well pumphouse.
Walls would rest on 8" thick footing, the bottom of which will be 32" below grade. The interior floor of the pumphouse would be a floating 4" concrete slab over a backfill of crushed stone/sand and 6" below grade.
Since the interior and exterior backfill will balance lateral forces, does anyone see a problem with using 4" below grade?
The Logix tech guide shows 4" can be used for crawl space walls no taller than 4'-10". This will be 5 courses of block or 6'-8", of which 2' will have interior and exterior backfill.
I plan to use #4 rebar: vertical @18", horizontal @16". Thanks Dave
