Posted By smartwall on 12 Apr 2012 07:56 AM
I didn't mean your ceiling had a problem it happens in ceilings, I gave this as an illustration of a place where this is noticable. You have heat transfer by conduction and no amount of shellac you use will cure the problem. The only way is to raise the insulation value where the screws are . Which is of course impossible in a reasonable way.
You are right when you say it is the heat transfer but it is probably the condensate that happens on the cooler screw heads that actually attracts the dust. You are also right in saying it is the steel in the ICF that is drawing the heat out of the screw and into the steel web and concrete. That is why some forms of scips and other products that use steel without an thermal break can also have this problem.
