Posted By scott clay on 11/26/2006 7:43 PM 1) Any problems with the FC sip delaminating from the poly because of heat/cold/wet/dry conditions.
There shouldn't be. All SIPS should have a lifetime warranty for delamination. If the manufacturer doesn't have that warranty, 'Dump The Dude'.
2) Even painted properly, the paint and FC will absorb some moisture, as they dry out, will that affect the paint bond to the panel.
Can't help you there. Sounds like a question for a 'Painting Forum'. |
