Quad-Lock Banner
Forums > Green Building Forums > General Forum - Residential > Subject: Place to recycle MDF dust?
ICFJambsMNUser is Offline
10/24/2007 10:51 AM
Greetings!
This is my first post to the forum, though I've been lurking for a while.  I am a member of the local builder's green building committee but lack a lot of knowledge in this area!
I work for a company that generates a steady amount of dust primarily from MDF-core panels, but also mixed with shavings from a couple shapers and an edgebander.
Right now, it collects into a mid-sized dumpster that gets dumped with the other end cuts and unusables en route to an incinerator.  The cost is reasonable, but I wish I knew of a better use for the (by)product.
Is there a better place to send this?  Thus far, http://stcloud.craigslist.org/sss/ hasn't had any takers!
teslastonesUser is Offline
10/28/2007 8:29 PM
I have a method that could make a ceramic cement based MDF or OSB board with such a waste.
The source must be close to be viable for me, however, I could teach you how to do it onsite.
Jonathan
10/29/2007 11:56 AM
Jonathan,
Where are you located? I'm in central MN.
I'd like to see what you have in mind.
10/29/2007 8:21 PM
www.shetkastone.com could probably do something with it. they are in le center MN
aheroincUser is Offline
10/29/2007 10:12 PM
I have been working with MDF dust also, I am in a area with plenty supply of dust,
how could we work together,
Toney
10/29/2007 10:18 PM
Call me tomarrow 479-899-7053
Jonathan
