Greenblock Banner
Find a Green Building Pro
Browse Project Albums
View Product Guide
dcook4User is Offline
02/29/2008 6:06 PM
If I am going to be building an SIP house, what is my best option for a basement. I am concerned about air flow and cold air getting in throught the basement and into t he main floor.  I live in Manitoba which has a very diverse climate.  Summer is +50 and winter is -50C.  Any suggestions.
GsfreyUser is Offline
02/29/2008 6:31 PM
Move.
Greg Freyermuth
915-256-7563, Cell
gregfreyermuth@elp.rr.com
Greg Freyermuth
915-256-7563, Phone
GregFreyermuth@elp.rr.com, E-Mail
02/29/2008 9:13 PM
Posted By dcook4 on 02/29/2008 6:06 PM
If your soil conditions are dry, you could use SIP basement panels. If not, I would go with ICF's with additional insulation on the inside.
....jc
olpjebUser is Offline
02/29/2008 10:13 PM
dcook4 -
If I had to do it again, I would ICF the basement. I had to heat my house's basement (through radiant tubes in the slab) in the dead of winter in Colorado so that I could get the drywall and paint in. It cost me a fortune because I did not have basement insulation (and my basement is about 2/3 buried in the dirt). At the very least, invest in 2 to 3" of EPS foam on the exterior basement walls, and be sure to put 3/4" or 1" foam board underneath your basement slab. It will cost a bit extra, but the payoff will come quickly at today's gas or electric prices.
03/01/2008 12:39 PM
olpjeb,
Which type of polystyrene would you use - expanded or extruded - under the basement slab?
334 329-0957 AT&T Cellular
03/01/2008 2:52 PM
Either will work, but I like extruded. It is easier to get where I live (Dow Blueboard) and it has a 25% better value for the same thickness of expanded PS.
aksmith42User is Offline
03/01/2008 11:06 PM
what about the reflective bubble wrap type insulation for under a slab?
rarickertUser is Offline
03/09/2008 1:36 AM
With basement SIPs... if you leave your basement unfinished, do you still have to drywall (cover) the interior SIP wall?
I read that with ICFs... in an unfinished basement you still have to cover the interior foam.
I was wondering is SIPs were the same or if the interior OSB ply was an acceptable covering.
03/09/2008 9:35 AM
Posted By rarickert on 03/09/2008 1:36 AM
rarickert;
this is a code related question and most codes require for "finished" areas a 15 min thermal barrier over "plastic" insulation, EPS is considered plastic. Normally 1/2" drywall is used.
I am not aware of a requirement for "unfinished" areas needing a barrier, I would not think that a building official would require the OSB be covered, but it is a matter of iterpretation of the inspector and at their descretion.
We always leave the inside of garage exterior walls on our steel SIP panels bare, as well as the garage ceiling (if there is no living space above)
chris@southernsips.com
PremierCUser is Offline
03/27/2008 12:48 PM
If you are going ot use basement qaulity sips, make sure that the skins are 5/8" thick .60 treated plywood with a structual member every 4' on center (treated  laminated glu-lam) for the possibilty of hydraulic pressure.  We back fill all of our sip basements and foundation panels with pearock for drainage  and to reduce hydraulic pressure.  We also set all these projects on pearock.  This is in Minnesota.  You do not need to cover with drywall.  I have seen a basement that the inner skin of treated plywood was stained with a batton strip on the verticle seams and a chair rail horizontal for looks.
