BuildBlock Building Systems LLC
Find a Green Building Pro
Browse Project Albums
View Product Guide
Forums > Green Building Technologies > Solar and Wind Power > Subject: Installing solar panels onto a ceramic tile roof (that has been installed onto concrete)
CarolVenturaUser is Offline
03/23/2008 8:21 PM
Our concrete roof only has a 2.25/12 pitch. I had ruled out ceramic tile because of the low pitch, but found out that it can be installed with foam adhesive over a waterproof membrane. My question now is – how would solar panels be installed? Would the brackets be secured over the tile (through holes drilled into the tiles - with screws that would go through the tiles to the concrete)? Or, should they be screwed to the roof before the tile is installed?
TopgasUser is Offline
03/24/2008 6:41 AM
I'm no expert on panel installation but I have done my own. First panels are bolted, second the panel mounts are placed on top of the roofing material.
Forums > Green Building Technologies > Solar and Wind Power > Installing solar panels onto a ceramic tile roof (that has been installed onto concrete)
