It is most efficient to place the HVAC airhandler and ducts all within conditioned space envelope. It does not necessarily need to go overhead , we prefer an easily accessable closet for future maintenance and replacement.
While the dropped areas in SIPs house will get conditioned thru duct leakage you are not fully conditioning the overhead space. While it may be pleasantly comfortable up there. Your supply ducts and return air will keep most of the air flow where it needs to be.
In a conventional system you ducts and air handler are fighting hot humid air greatly reducing efficiency.
A reason why your HVAC in a SIP house must be downsized and properly designed. |
