Quad-Lock Banner
Forums > Green Building Technologies > Geothermal Heat Pumps > Subject: Split or Replace?
buymyemuUser is Offline
04/19/2008 12:25 PM
I have a 3200 sq foot ranch, with a full walkout basement.  Carrier inffinity series propane (96%?). 2 by 4 walls, cellulose. System has just seen its 3rd winter.
Propane running about $800/month in Dec/Jan/Feb.  Flint Michigan.
3 quotes so far to replace with a ground loop system (10 acres).  All state 5 ton is adaquate.
2 quotes want to replace the entire system with their brands, both 2 stage.
All 3 say the duct system looks fine.
One installer mentioned a split system, he would only add an A coil to the existing and leave the propane as a backup.  Climatemaster 27 (Affinity?) is what he mentioned.  would then need a 3 stage thermostat, my guess is propane as the 3rd stage.  Obvious short term cost is lower.
Other 2 guys will replace entire system and have electric as the backup heat source.
Propane has to stay for the fireplace.
One of the other 2 guys stated that it could not be set up as a split with propane backup.  Looking on the internet seems to say otherwise, so I am not sure if I trust him.
1) Is it ok to add a split system and leave the propane as stage 3.
2) will it be cost effective in the long term (propane should hardly ever need to come on?
3) If propane comes on, does the geo shut off, or all 3 stages run at once?
4) Will sell house in 5 years if market improves (so I will never be moving!)
Any ideas on which way to go?
Frank
04/19/2008 4:16 PM
Additional info:
Has a 10 seer carrier AC 5 ton
Infinity thermostat single zone, can handle 2 HP and 2 gas furnace heat stages?
Eric DUser is Offline
04/19/2008 4:42 PM
Frank,
Your just north of me by about 20 miles.  I'm In Howell.  I'm heating 2270 sq ft plus 1450 sq ft basement with an open loop 3.5 ton unit.  My home is 2 x 6 walls a little over r19.  With a closed loop system a 5 ton would most likely be all you need.  I kept my propane 90 plus furnace as you suggested you are planning, I thought I might needed if it really go cold.  Even with -5 deg temps outside the 3.5 ton kept us warm.   I would suggest against trying to do a split system with the propane system.  Make sure the duct work that connects the geothermal unit to your current ductwork is sound insolated on both supply and return.  The added air flow can make the system very noisey without the insolation.
Keep us posted on how things are going,
Regards,
Eric D
Southern Michigan
04/20/2008 9:50 AM
Thanks for the reply Eric.
I was leaning to keeping the Carrier system just because it is nearly new and that contractors price is much lower (much less work for him to install?).  There is an electrostatic air filter and humidifier on the system, contractor C might not have to move those, whereas the other 2 would
Do you think you have lost any efficiancy by keeping your propane system?
Did you put the geothermal after the propane burner or on the return side?
Thanks again.9:47:37 AM
04/20/2008 11:32 AM
Posted By buymyemu on 04/20/2008 9:50 AM
Frank,
The duct work in my home was over sized and works well with the geothermal arangment.
My system is quite different from the norm. The propane system and the geothermal unit are in parallel to the main feed plenum. I have ducting dampers that isolates the unit not in use from the duct work. The design has powered dampers being controlled through relays that only allow one unit at a time to function. The heating unit switch is made by selecting emergency heat from the thermostat.  This shuts down the geothermal unit, switches duct dampers and activates the propane furnace only after the dampers are fully open.
After going through this last winter I have found that the geothermal unit keeps up just fine with the heating demands. The current plan is to leave the propane unit though it really isn't needed.
On any split system the geothermal must be on the return side of the propane unit.  The only other choice is a parallel system where one or the other heating unit is used.
Efficiency could be affected with a split system trying to circulate through the propane unit. This would add a lot of flow restrictions.
Eric D
Southern Michigan
