Amvic Banner
slfriedmUser is Offline
04/24/2008 6:52 PM
As I stated in my last post (my first) I am new to this geothermal thing.
I can not figure out how payback is calculated.  It seems that payback is calculated differently depending on what you read.  How can a 20k investment be paid back in 4 to 5 years if your are only saving 1k a year?
cnygeoUser is Offline
04/24/2008 8:53 PM
It really comes down to your individual situation. The money saved with a geo system is a factor of relative fuel costs, system efficiencies, and the amount of heating and/or cooling energy your house consumes in a year. Annual savings can range from next to nothing when compared to a good air-source heat pump in a temperate climate to several thousand dollars a year in high heating or cooling load climates. There are several good web sites that will let you calculate the savings with decent accuracy, I don't have my bookmarks handy but will post when I locate them.
Also, if you let us know your approximate location, current heating/cooling system, and approximate annual operating cost, I or one of the other folks here could give you a quick guesstimate of how much you could save with a GSHP.
Payback can be simple or complicated depending on how you think. Simple payback is just install cost divided by annual savings. A more proper way would be to factor in the cost of capital or opportunity cost (Not sure if these are the right terms, I'm not a money guy), in other words if you invested that $20k, how much would you make on it vs the savings form a heat pump.
New construction or replacement of a failing existing system will also help the payback time. I had a 50 year old boiler that needed to be replaced at a cost of $8500. As my geo system was about $15K, the additional cost was only $6500, so my payback will be a little over 2 years (I think my case is pretty extreme in that regard). If you have a relatively new HVAC system that has years of life left in it, the whole cost of the Geo system must be included, so the payback won't be as good.
bobgieserUser is Offline
04/29/2008 12:24 PM
If a air to air heat pump was going to cost 10,000 and a geo is estimated at 20,000 then the extra 10,000 is spread out over the savings of using the geo-thermal vs. alternative unit. If geo can save 100 a month over the other unit (yearly average), 1200 a year gives you 8 year pay back. The life expectancy of the geo is most likely 20+ years and the other is ???
Bob Gieser
Sales and Technical Support
Holdfast Technologies
Master Distributor for Nudura ICFs
(916) 214-4398-cell
TechGromitUser is Offline
04/30/2008 9:21 AM
This Link provides a useful resource to compare the saving over one method of heating over another.
