Amvic Banner
Forums > Green Building Forums > General Forum - Commercial > Subject: Bamboo floornig VS laminate flooring
no10williamUser is Offline
06/21/2008 1:42 AM
Laminate flooring(LF) and bamboo flooring(BF) are both of wood flooring. But they have their own features.
1. Abrasion resistance
LF is strong abrasion resistant. AC4 and AC5 rating LF can be used for heavy commercial purpose. It can be used in many high traffic indoor places such as gymnasium and supermart. Bamboo flooring is not strong abrasion resistant. It can’ be used in high traffic place.
2. Price
LF is much cheaper. The prices of bamboo is usually 3-4 times higher than that of BF.3. Moisture resistance Both of the products are strong moisture resistant. But BF is much better. BF even can be used in kitchen. The swelling rate of BF is very low.
4. Durability
Regarding durability, BF is better than LF. LF can’t be repaired if the top layer, abrasion resistance, is broken as there is no layer to protect the decorative layer and support material. BF still can be used if its surface is broken because there is still bamboo under the surface.
5. The content of formaldehyde
BF is mainly made up of glued bamboo planks, while the support material of LF consists of glued wooden fiber. So the content of formaldehyde in laminate flooring(LF) is times of that in bamboo. But LF is also safe as long as it meet the standard of formaldehyde release.
6. Colors available
Almost all the colors can be available to LF: pine, oak, birch, beech, cherry, oak, teak, walnut, ceramic tile, granite, marble and even including bamboo. But the colors for bamboo flooring(BF) are just natural color, carbonized color and several other colors.
7. Appearance
BF gives a natural, elegant and comfortable feel. It makes your house more valuable. Common LF can’ t offer such feel. But now there is some type of LF with hardwood like appearance such as V groove type and hand scraped surface.
8. Noise.
LF is of a floating type. There is some noise when people step, while there is only a little noise from BF as its installation method is quite different from LF. It is not a floating type. But attached underlayment on the back of LF can reduce most of the noise.
Forums > Green Building Forums > General Forum - Commercial > Bamboo floornig VS laminate flooring
