Even if we get past the building inspector, I wonder about these toothpick size objects. If you are trying to get the vibrator down through a 6" wide opening and from what I understand small vibrators are hard to come by, these toothpicks may get pushed together or clump up. Maybe not, the other area of concern is rusting. They say they are galvanized, will Galvaized toothpick size metal not corrode in a short time.
What am I saying, wire holds up, this stuff should too. I realize you would still need rebar between the cold joint (foundation and wall). I like the idea, especially after I have heard about the cost and labor of rebar. |
