Quad-Lock Banner
ManfredUser is Offline
12/03/2008 3:22 PM
I like to reach all ICF experts with this topic: I have lived in Canada for over 20 years and crawl spaces are a mystery of the past, mainly they are ineffective regarding energy usage. I have lived in North Carolina for over 10 years now and have encountered the request for crawl spaces almost 100%. Crawl spaces harbour a lot of disadvanteges for the living comfort of the inhabitants. What do you think about the crawl spaces? I surely don't understand it - specifically in this time of technological advancement in building science. Any takers? I don't want to bash anybody's thinking or reasoning, just want to hear the different opinions of the pros and cons. Thank you.
Manfred Knobel
Moss Pointe Builders, Inc.
Talisker2User is Online
12/03/2008 4:03 PM
Hi Manfred, I am not a builder but from my limited experience (I live in Anchorage AK.) Crawl spaces are common here but I may be forced to use a FPFS when I build on my lot in Wasilla only because the ground water table is high enough and the lot is pretty flat, it would be very expensive to dig a full basement needing constant pumping while under construction and then getting it completely sealed. The FPSF or frost protected shallow foundation which will be my best choice.
I guess I could go with a crawl space but don't care much for the problems with moisture, and the need for a sump pump and being pretty much unable to drain the water away from the structure.
