I used a product called BTS Plus from Sto to parge the area between the siding and the Miradri 860 membrane. It adheres directly to the ICF foam. I had to use some 60 grit sandpaper to rough up the peel and stick membrane to get adhesion on the overlap.
I can't understand why you would when there is a better product available
As often happens, I don't think it is a matter of "a better product", but a different product. I have one section of retaining wall where the laborers worked 2 hours unsupervised during the backfill. That means they backfilled without compacting when the supervisors weren't looking. We've had three months of unseasonable rain and 7000 square feet of roof dumps all that water right next to the foundation. There was more than 2 feet of subsidence in that section. The earth ripped off the air barrier, dragging it down and crumpling it as it settled, but the peel and stick stayed intact due to good adhesion and the basement is still dust-dry despite 12 feet of water up against it.
