| 20 Oct 2011 06:02 PM |
"From this last picture you can begin to see the enornity of the structure, 23 ft. tall side walls, underside of main roof span is 36ft. at center from slab, tall enough to install a third floor loft area over the theater." I take it this isn't just a cozy weekend getaway shack for a retired couple! :-) I'm sure we've all been in barns with less interior volume!
cmkavala
| 20 Oct 2011 06:09 PM |
Posted By rnortman on 20 Oct 2011 05:39 PM
What's happening at the top of that post? How are the panels connected there? Is the post temporary or permanent?
The post is temporary, the top is a crcular metal cone, each pie shaped wedge ( 32 pcs) is stitch screwed to center cone. Each cut joint is stiched together with metal skin top and bottom. Eave end is fastened with LD sip screw to top wall cap |
cmkavala
| 20 Oct 2011 06:11 PM |
Posted By Dana1 on 20 Oct 2011 06:02 PM
Two doctors |
cmkavala
| 20 Oct 2011 07:03 PM |
84 job photos at this link: http://www.myspace.com/steelsips#!/steelsips/photos/albums/odessa-job/1607193 |
cmkavala
| 29 Oct 2011 06:58 AM |
updated...............
Top view of Hip roof
multi sided roof
 top view of round roof, overhang tails running wild will now be cut back to 24"
JeffD
| 30 Oct 2011 02:24 PM |
This is one of the most complicated metal sip homes I have ever seen built. Nice work! Thank you for the photos. |
| Metal SIP Building Designer<br>jeff@panelfusion(dot com) See us on Facebook |
Jelly
| 11 Nov 2011 08:21 AM |
This project is nothing short of AWESOME! Chris, you said the overhangs are going to be cut in place... Will you just cut both sides of the panel like usual, or is there another method you have up your sleeve? Also, that looks like 18 gauge brake metal at the hip, but what sort of profile is it? Looks like an "H" but maybe it's two "C" channels screwed back to back? |
cmkavala
| 11 Nov 2011 10:09 AM |
Matt;
attached is the detail less the 26 ga. cap on top is not needed
Tails are cut on both sides as usual for a plumb cut |
cmkavala
| 11 Nov 2011 07:13 PM |
MarinoWare Joists............................
We normally use Dietrich TradeReady and decided to try MarinoWare JoistRite, promised 2 week delivery that turned into a 6 week wait. A real killer on the construction schedule |
Jelly
| 13 Nov 2011 08:22 PM |
Look at all those joists! That is a monster of a house. Was the MarinoWare price in line with Dietrich? |
cmkavala
| 13 Nov 2011 08:58 PM |
MarinoWare was slightly less on this house and I had been wanting to try them, but not worth the waiting time, unless there is some compelling reason, I will be going back to Dietrich in the future, simply because the lead time is usually 2 weeks or less |
cmkavala
JeffD
| 20 Nov 2011 09:42 PM |
I have used them in a few projects and like them from a designers point of view. With all those cut outs they are really flimsy. Make sure you follow the bridging recomendations. Addedly, if you can't get them on time, thats unaceptable. |
Torben
| 21 Nov 2011 06:36 AM |
I was able to adjust my plans to not need the larger holes. I ended up just going with solid clark-western 14-inch, 14-gauge studs and track. I used 2.5" channel for bridging (just clip out sides at each joist) and L-sections for clips. The studs have sufficient holes to run wire but the increased stiffness allowed me to adjust my joint spacing (overall a tremendous difference in price). I got prices for Dietrich and Marino Ware, Marino Ware was slightly less (but delivery time for both was several times that of Clark-Western). I guess Clark-Western and Dietrich have merged but I imagine the price/time difference is still about the same. |
cmkavala
| 21 Nov 2011 08:27 PM |
Jeff;
14 ga. with a 3" width made joists plenty stiff, but cannot wait 6 weeks for materials
Torben;
needed the webs/holes for mechanicals, I am using the stud only for a third floor loft (after thought) where plumbing and HVAC is not needed in the joists. |
Jelly
| 22 Nov 2011 07:40 PM |
Those shiny steel joists are too pretty to cover up with plywood!  |
cmkavala
| 22 Nov 2011 09:27 PM |
Posted By Jelly on 22 Nov 2011 07:40 PM
Not using plywood in this one, decking will be 2" thick mag board SIPs |
Jelly
| 23 Nov 2011 01:18 AM |
You sort of just blew my mind with that one. I didn't know Mag board was even passing the sniff test yet. I guess I've been away from the forum for too long!
cmkavala
| 23 Nov 2011 06:05 AM |
Posted By Jelly on 23 Nov 2011 01:18 AM
we will let you know the results in a while, and render and opionion |
Torben
| 23 Nov 2011 01:18 PM |
Wow Chris you've been full of surprises on this one. Congratulations on a phenomenally innovative SIPS project. I'll certainly be interested in your results. What is the actual thickness of Magboard you are using? |
