Amvic Banner
UnregisteredUser is Offline
02/23/2004 8:58 AM
I am thinking about installing radiant heat and am hoping to avoid the cost of gypcrete. I read the article referring to Yonker's mix. The article mentioned the recipe in figure 3, but there was no figure 2 on the linked page. Does anyone actually have the recipe? Is it possible to mix by hand or does it have to come from a readymix plant?
02/25/2004 5:13 PM
The article is from Journal of Light Construction, July 1995. Author of article was J Siegenthaler.
The mix recipe was:
Type 1 Portland cement 517 lb.
Concrete sand 1,630 lb.
#1A (1/4" maximum) peastone 1,485 lb.
Air-entrainment agent 4.14 oz.
Hycol (water-reducing agent) 15.5 oz.
Fiber mesh 1.5 lb.
Superplasticizer (WRDA-19) 51.7 oz.
Water about 20 gal.
Footnote text from figure:
Note: These mix proportions make one cubic yard of 3,000-psi concrete floor topping (strength rated at 28 days). The high-slump concrete recipe creates an easy-to-pour mix that flows well around the tubing, providing excellent thermal conduction between the tubing and the concrete.
When I asked the local redimix plant guys about a lightweight mix, they wanted to add a 'foaming' agent. Seemed to me that you'd want to steer clear of anything that introduced air or foam into the mix - if conduction is what you're after.
jasahlUser is Offline
01/27/2006 11:14 PM
I know this is old, but does anyone know how Youker's mix compares to regular concrete in terms of weight? Based on the ingredients listed, & it seems it would end up being ~ 140 pcf meaning that a 2" slab would weight ~23 psf - is it normal to use something that heavy as a suspended slab?
01/30/2006 9:45 AM
Wow : I would be scared to use anything at even 20 psf without a through analysis of internal loads & wall loading based on a solid approved design. I doubt your building inspector would be satisfied with anything less
Search GreenBuildingTalk:
Professionals Serving
Your Location:
Project Albums:
