SIPstech Banner
Find a Green Building Pro
Browse Project Albums
Search Homes for Sale
Forums > Green Building Technologies > Radiant Heating > Subject: slab insulation for shop
alfalfaUser is Offline
07/14/2004 9:00 AM
we are building a large farm shop for equipment repair. 52x60x18. steel framed building. this is being built on piers 5 ft down with a slab poured on grade. how much insulation is needed on a slab this size?? which is best, rigid foam,tek foil(from farmtek) or that insultarp. what r value do i need?? what about the sides of the slab?? thanks
UnregisteredUser is Offline
07/14/2004 5:30 PM
At very least insulate the edges with rigid foam.
Several feet in form the edges is the next step
Preferred would be under the entire slab with 2 inches of foam.
You will pay for it as insulation or fuel
OKBlockerUser is Offline
07/19/2004 8:24 AM
Alfalfa,
Why not use the InsulTarp and do a radiant floor heat?
ART's Mark Ross has a neat "Plug & Play" system that is very user freindly. They are heating a 6,000 sq ft training facility with radiant floor heating using only a 34 gal hot water heater!
Contact him.......http://arit.com/
07/05/2005 9:52 AM
quote:
Originally posted by alfalfa
we are building a large farm shop for equipment repair. 52x60x18. steel framed building. this is being built on piers 5 ft down with a slab poured on grade. how much insulation is needed on a slab this size?? which is best, rigid foam,tek foil(from farmtek) or that insultarp. what r value do i need?? what about the sides of the slab?? thanks xxx
07/19/2005 4:27 PM
Be sure to use vertical insulation around the perimeter of the building as a minimum. Horizontal insulation across is absolutely required if you have a high water table (the water will carry away your heat). If you do not have a high water table, I suggest horizontal insulation at least four feet in all the way around the building. This way, the heat has to travel into the ground, travel out four feet, then back up and out. Insulation all the way across the floor will increase efficiency, but the incrimental increase has a long payback period.
Nick ahipdude@msn.com
08/18/2006 10:02 AM
Forums > Green Building Technologies > Radiant Heating > slab insulation for shop
Professionals Serving
Your Location:
Sierra SIPs (San Andreas, CA)
View More
GBT Project Albums:
the future (orange, NY)
Partial radiant heat (lake katrine, NY)
Lovelace Home (Spartanburg, SC)
geothermo heat system (Savannah, NY)
myFirstRenovation (Staten Island, NY)
More Info |  Search
