Fibertec Banner
Forums > Green Building Technologies > Radiant Heating > Subject: radiant heat WITH CERAMIC TILE
nycstevUser is Offline
02/18/2005 9:56 AM
WE ARE PLANNING TO INSTALL HYDRONI RADIANT HEAT OVER EXISTING WOOD SUBFLOOR. WE WILL INSTALL CERAMIC TILES AND ARE CONCERNED WITH CRACKING.
IS IT BETTER TO USE 1.5 CONCRTETE SLAB OR SLEEPERS FILLED WITH CONCRETE AND WONDERBOARD OVER. IS IT NECCESARY TO USE WIRE IN SLAB?
gordbUser is Offline
02/18/2005 2:48 PM
You will need to make sure your floor system is capable of carrying the extra dead load of the concrete. If it is capable, I have a mix from PCA for this application. You may need to go a bit thicker depending on your tubing thickness. If you would like the mix let me know I'll dig it up,....or just call PCA and they can answer any of you questions. Another option that may work better depending on your situation is easyfloor,......check it out at www.easyfloor.com.
goog luck,.........Larry
UnregisteredUser is Offline
02/28/2005 10:47 AM
I am also considering Easy Floor, but I haven't heard from anyone that has used it. Seems very easy and would be more responsive to heat changes than in slab installation. Anyone out there used this?
Forums > Green Building Technologies > Radiant Heating > radiant heat WITH CERAMIC TILE
Search GreenBuildingTalk:
Professionals Serving
Your Location:
Project Albums:
