News/Blogs
Project Album
Directory
Products
Services/Advertising
Radiant Heating
> Subject: Boiler vs Hot water tank?
Prev
Next
Author
Messages
Oldest First
Newest First
Davee
05/11/2005 8:15 PM
Anyone help with comparison of efficiencies. Are the AFUE tests different on a tank Vs a boiler? A tank normally sees more cold water than a boiler so getting higher efficiency on a test should be easier in a hot water tank but lower in a radiant heat situation
Unregistered
05/28/2005 4:34 AM
Hot water tanks under 200,000 btu's are not require to have an AFUE rating. That leaves you to try and compare EnerStar ratings for these products. A typical tankless has a combustion efficiency of 82% compared to a standard boiler of 85%. Not much difference really. The tankless is well suited to a combined installation DHW and space heating where the DHW load is larger than the space heating load. If this is not the case (as in a basement floor warming system) and you want to heat a whole house, buy a boiler.
Green Living
--<a href="http://discuss.greenoptions.com">Green Options</a>
Radiant Heating
Search GreenBuildingTalk:
Your browser does not support iframes.
Professionals Serving
Your Location:
Project Albums:
Copyright 2008 by BuildCentral, Inc.
Terms Of Use
Privacy Statement
