BuildBlock Building Systems LLC
UnregisteredUser is Offline
12/15/2005 5:06 PM
ive got a 15x30 slab about to be poured...ive got 2" of blue board down, and around the perimeter.....duck taped at all the seams....
do i need to put wire mesh down or can i just duck tape the pex to the blue board to hold it down while the cement is poured?
also...how important is the pressure test? do i really need this? how common are leaks straight from the factory?
thanks J
OKBlockerUser is Offline
12/16/2005 1:48 PM
John,
Wire mesh would be beneficial in that it will strengthen your slab and give you something to hold your Pex layout to.
Look at: http://www.insulationsolutions.com/products/quip
If you have zero fittings in your Pex under the slab, then a pressure test is not as important but it would be better to know now than later in my books.
Search GreenBuildingTalk:
Professionals Serving
Your Location:
Project Albums:
