Fox Blocks
Forums > Green Building Technologies > Radiant Heating > Subject: pex foot damage
UnregisteredUser is Offline
01/09/2006 9:45 AM
my the cement guys were walking all over my pex while pouring cement...even carting the wheel borrow over it...i told them to be careful and they told me that there was nothing to worry about...but if it turns out i have a leak....i have no recourse....so my question is....what are the odds that my pex has been damaged by less-than-careful cement work...? and...how will i know if i do have a leak under 6 inches of cement? thanks
OKBlockerUser is Offline
01/10/2006 10:04 PM
John,
"but if it turns out i have a leak"
Did you have pressure test on the Pex during the pour?
Most contractors will pressure up the system and keep a guage on it during the slab pour and after.
If the Pex was not centered in the concrete and lays closer to the bottom of the slab, you may never locate a leak. The moisture will always take the path of least resistance and may never surface.
01/11/2006 10:59 AM
great....i cant beleive those guys were stomping all over my pex like a bunch of gorillas.....'we done it for 20 years like this....never had a problem' they said...
no....i did not pressure test....i had two 250' circuits....probly should have....
01/12/2006 1:43 PM
John,
Go ahead and put a low pressure test on each loop and see what you get.
You may get lucky!
01/13/2006 11:41 PM
that is what i will do ....thank you....
Search GreenBuildingTalk:
Professionals Serving
Your Location:
Project Albums:
