Project Album
Newsletter
Directory
Products
News
Blogs
Services/Advertising
Welcome to
- the place to share, ask and learn about green building products and methods. While you can browse the site as a guest, you need to register in order to post.
Registration is fast, simple and free so join our community today.
Radiant Heating
> Subject: 1"1/2 of portland cement over radiant heat
Prev
Next
Author
Messages
Oldest First
Newest First
hulk
05/12/2006 3:02 PM
I have already put my subfloor down and am planning on pouring 1"1/2 of portland cement over the radiant heating. I now I need a barrier between the concrete and the subfloor. What should I use? Also i understand i need to put expanding joints in to prevent cracking. Is there anything else I should do to help a better outcome?
Unregistered
05/14/2006 12:41 PM
Surely the supplier of your system has recommended practises? Please follow them so Radiant does not get a bad name. Too many THINK they know enough to do the job & foul it up.
Glen
05/16/2006 4:32 PM
Use 30# felt as barrier. Mix 1 Part Portland cement with 3 to 4 parts sand. Mix very dry the mix should be moist not wet. Use 1” dia. galvanized pipe as secreting glides. Tamp the mixture and secrete off using the pipes as a glide. You can use wire mesh for reinforcement if desired. Remove the pipes and fill the holes while mixture is still uncured.
hulk
05/17/2006 3:34 PM
Glen I am a little confused? I thought the pea gravil or 1/2 gravel is what gives the concrete its strength. I dont understand using 1" galvanized pipe as secreting glides or tamp the mixture and secrete off using the pipes as a glide. Could you please explain.
thanks
Green Living
--<a href="http://discuss.greenoptions.com">Green Options</a>
Radiant Heating
Search GBT's Professional Directory:
Choose Technology Below
ALL
Insulating Concrete Forms
Structural Insulated Panels
Radiant Heating
Geothermal Heat Pumps
Solar Power
Sitework & Landscaping
Decking
Outdoor Structures
Foundations, Footers, and Slabs
Structural Systems & Components
Sheathing
Exterior Finish & Trim
Roofing
Windows/Doors
Insulation
Flooring & Floorcoverings
Interior Finish & Trim
Paints, Coatings & Adhesives
Mechanical/HVAC
Plumbing
Lighting
Electrical/Audio/Video
Appliances
Furniture & Furnishings
Renewable Energy
Distributors & Retailers
Home Performance Testing
Financial Services
Education/Publishing/Trade Organization
Miscellaneous
Choose State Below
ALL
Alabama
Alaska
Arizona
Arkansas
California
Colorado
Connecticut
Delaware
Dist. of Col.
Florida
Georgia
Hawaii
Idaho
Illinois
Indiana
Iowa
Kansas
Kentucky
Louisiana
Maine
Maryland
Massachusetts
Michigan
Minnesota
Mississippi
Missouri
Montana
Nebraska
Nevada
New Hampshire
New Jersey
New Mexico
New York
North Carolina
North Dakota
Ohio
Oklahoma
Oregon
Pennsylvania
Rhode Island
South Carolina
South Dakota
Tennessee
Texas
Utah
Vermont
Virginia
Washington
West Virginia
Wisconsin
Wyoming
--------CANADA--------
Alberta
British Columbia
Manitoba
New Brunswick
Newfoundland and Labrador
Northwest Territories
Nova Scotia
Nunavut
Ontario
Prince Edward Island
Quebec
Saskatchewan
Yukon
Get Listed
Professionals Serving
Your Location:
Creative Panels
(Kingsburg, CA)
Amvic-Pacific
(Nevada City, CA)
Sierra SIPs
(San Andreas, CA)
Blue Lupin Developments
(Incline Village, NV)
Greenblock Worldwide Corp
(Cave Creek, AZ)
View More
GBT Project Albums:
ICF Home
(Southern Utah, UT)
Geothermal Install
(Purcellville, VA)
My Home Project
(North West, FL)
new home
(south, TX)
New Home
(Hiram, GA)
More Info
Copyright 2008 by BuildCentral, Inc.
Terms Of Use
Privacy Statement
