Enercept Banner
Forums > Green Building Technologies > Radiant Heating > Subject: Radiant heat? Warm room cool floor
ecUser is Offline
07/09/2006 5:30 PM
We have a room that is below grade. In the past the room has been warm, but the floor cool. We have a gas wall heater. The floor had rigid insulation under plywood and a mat and rubber carpet underlayment over the plywood.
We are in the process of foundation work and will be pouring a new concrete slab so we have the opportunity to revisit warming the floor. We're considering radiant heat. We don't need to heat the room from the floor. But we would like a warmer floor as we do yoga and exercises on the floor.
Any comments or suggestions would be greatly appreciated.
UnregisteredUser is Offline
07/09/2006 6:05 PM
Any radiant heat product must "obey" certain rules regarding spacing to avoid heat striping . While you can work with a low temperature in the system, the installation cost will approach that of an independent system. Could yo just heat small areas using electric?
07/10/2006 11:40 AM
I would concur that if you are not tying into an existing hydronic system, I would consider electric for a small add on like this.
-=Northeast Radiant Technology, LLC=-
www.NRTradiant.com
NRTradiant.com
Forums > Green Building Technologies > Radiant Heating > Radiant heat? Warm room cool floor
Search GreenBuildingTalk:
Professionals Serving
Your Location:
Project Albums:
