hi ona
all ductwork out side of the thermal boundary(your basement/garage) should be insulated
heat transfer from your old oil boiler was fine,from your new geo system its not
i would still insulate and air seal as best as you can
did you have a bpi energy audit done?
if you do nyserda will contribute a substantial portion you should get something from the state toward your energy conservation measures
good luck
jason
