bpwrightwv
| 26 Nov 2008 03:54 PM |
Doing some research on spray foam, and came across a few do it yourself kits for home insulation. Anyone use these? Thoughts, in general? Looks 'simple' enough.
Bruce
| 26 Nov 2008 05:37 PM |
I considered it to do the rim joist area of my house. Turned out that I could hire someone to do it with one of the big rigs for less than the cost of one of the kits. |
Summers
| 26 Nov 2008 09:36 PM |
Great Material, I have used the small tank application [2- 20lb. propane sized tanks & about 10' of hose] Works very well in confined/restricted spaces and where a "Big Rig" would involve routing hoses up stairs, thru crawl ways, and small attic access. Material expands Very Rapidly, and in a matter of 10 or so sq. ft. you can get a handle on dwell time in relation to thickness you want. Tenacious bond qualities to Anything, so don't spray it where you will have to remove it. Used it [as a stopgap measure] on the interior of a barn built in 1860 with Chestnut siding 4 years ago. Siding is no longer warping, interior is waterproof and I no longer have to continue re-nailing the siding on a mothly schedule. A little on the expensive side, but easy to work with! Keeping the spray tips clean is important. If you stop spraying for more than 5 minutes, the tip will clog up on you. Estimate the coverage you will get out of a set of tanks, and prep for that amount of continuos application. It's so much fun, you'll have a problem stopping. Good Luck |
| The Cost Effective Answer to Concrete Corrosion |
Jelly
| 27 Nov 2008 10:44 AM |
I looked into it a few months ago and found it was cheaper to hire it out, at least in the size application I was looking at (~3000 sq feet of surface area). |
stonecaveman
| 01 Dec 2008 08:15 PM |
I'm looking to do this on top of EPS. The (recycled) EPS had a good price point. I'm putting it around the crawlspace walls on the inside. I'm planning to spray about 1/2" of one of these foams on the installed EPS to seal it against infiltration and to give it a better fire resistance. This seems to give me a good solution. Low cost insulation using the EPS, easy (easier) installation since I don't have to cut it too close if I fill all the leaks by covering with spray foam.
Any thoughts? Will it stick? Will it work?
