American Polysteel
For Advertising Info,
Find a Green Building Pro
Browse Project Albums
View Product Guide
Forums > Green Building Technologies > Insulating Concrete Forms (ICFs) > Subject: WATERPROOFING ON THE INSIDE ?
DAYUser is Offline
02/01/2002 7:20 AM
Here's one for those in the know. My poured slab will be 22" above the footing on fill within the completed ICF system. I'm on fairly wet lowland. Should I waterproof the inside foam as well as the outside below grade?
Ian ICF BuildersUser is Offline
02/01/2002 3:18 PM
YES. Water will wick up the wall otherwise. You may want to seal the construction joint between the slab and wall as well. You may also want to install a drain field under the slab that is tied to a sump well and pump if the potential for extreme amounts of water is possible.
Professionals Serving
Your Location:
Sierra SIPs (San Andreas, CA)
View More
GBT Project Albums:
magnolia remodel (seattle, WA)
Cottage (Rio Nido, CA)
Our new house (Burt, MI)
The RANCH (Williston, SC)
off grid SIP modern house kit (Charlotte County, VA)
More Info |  Search
