Amvic System Banner
For Advertising Info,
Find a Green Building Pro
Browse Project Albums
View Product Guide
LARRYUser is Offline
03/07/2002 10:02 AM
What are some ways to finish the deep window ledges on an icf wall? I plan on returning drywall back to the window. I would like the bottom of the window ledge to be a little more durable than drywall. How does painted plywood or birch look? Are there other options?
Thanks.....Larry
UnregisteredUser is Offline
03/07/2002 10:35 AM
Larry,
Have you thought of using Corian for your windows sills?
You can run sheetrock returns to the windows or you can use birch, ash or other wood products as well. Do a matching window sill out of the same wood. Looks great!
ICF372User is Offline
03/07/2002 11:03 AM
Larry, drywall returns are great. If you used pressure treaded for bucking do not attach directly with drywall againist the bucking. This can cause cracks later on.
Eldon Howe
Eldon Howe
Howe Construction
Total Concrete Homes provide positive cash flow , DAY ONE .
03/07/2002 11:26 AM
WHAT ABOUT USING DRYWALL FOR THE TOP AND SIDES AND BIRCH FOR THE BOTTOM? IS THE DIFFERENCE IN THE MATERIALS OBVIOUS?
THE BOTTOM OF THE SILL AS WELL AS THE TOP AND SIDES ARE SHIMMED AT ABOUT 16" O.C. TO KEEP THE WINDOW SQUARE. THE WINDOW HAS BUILT IN 1/2" DRYWALL RETURNS. I AM CONCERNED ABOUT USING DRYWALL FOR THE BOTTOM BECAUSE THER IS NOT CONTINUOUS SUPPORT (JUST WHERE THE SHIMS ARE).
THKS...LARRY
03/07/2002 11:29 AM
quote:
Larry,
I Do like corian. I've seen how expensive corian countertops are, it seems like it would cost a small fortune to wrap them in corian. I am thinking of possibly using marble though.
thks.....Larry
enermizermuskokaUser is Offline
03/07/2002 2:56 PM
Larry if it is the "support" between the shims issue, may I suggest that you place the
drywall in the window slots firmly and fill under with the Low expansion enerfoam and push down into place,after set up trim off any that oozed out. Birch or poplar look nice both painted or stained. Just a thought,
hope it helps.Take-care,sincerely.C.Kerr
Chris DeLucchiUser is Offline
03/07/2002 7:34 PM
Have you considered a concrete window sill? Think concrete countertop here. There is an example of casting concrete window sills in-place in Fine Homebuilding's "More Small Houses" page 131. The example uses crown molding and some 2x4s to cast in-place after the drywall is up (stick frame construction).
The downside of solid wood is fading and water staining is likely. I would be very concerned about plywood delaminating with prolonged sun exposure.
James EggertUser is Offline
03/08/2002 9:17 AM
Although the issue here appears to be durability, it really is what is the substrate? Ignoring the drywall returns for the moment decide on what you feel comfortable with under your selected finish product. The foam suggested by Chris will work and drywall will take sunstantial abuse under normal residential situations, but I think you are missing other opportunities here for making your own statement.
Here are details I use, sometimes all on the same house.
1. Drywall returns total
2. Drywall returns adding casing for a more finished look. The sill in this case can be whatever.
3. Full wood returns, stained or painted. I generally use a picture frame look versus sill and apron. There are times for each to be used.
4. Ceramic tile. Great look providing another texture. These can be drywall returns for sides and top, and also be cased if a more formal look is desired.
5. Thin cut stone and slate. See #4.
Considering you lean against your drywall walls spaced @16", I would not worry about a drywall sill thats maybe 7" deep, assuming you furr at the leading edge. If you really are worried about it, go with a birch 1/2 plywood and drywall combo, painted. I would avoid the luan plywood because you spend all your time sanding after the grain lifts.
Don't limit yourself to what you can do to be different!!
Take Care
Jim
Edited by - James Eggert on 03/08/2002 09:18:31
Take Care
Jim
Design/Build/Consulting
"Not So Big" Design Proponent
markrossUser is Offline
03/09/2002 10:29 PM
Chris D.
Never thought of that, excellent Idea.
Thanks.
Mark Ross
"Le Canuck"
03/11/2002 7:32 AM
WOW! THANKS FOR ALL THE IDEAS!
.....LARRY
Professionals Serving
Your Location:
Sierra SIPs (San Andreas, CA)
View More
GBT Project Albums:
magnolia remodel (seattle, WA)
Cottage (Rio Nido, CA)
Our new house (Burt, MI)
The RANCH (Williston, SC)
off grid SIP modern house kit (Charlotte County, VA)
More Info |  Search
