News/Blogs
Project Album
Directory
Products
Services/Advertising
For Advertising Info,
Welcome to
- the place to share, ask and learn about green building products and methods. While you can browse the site as a guest, you need to register in order to post.
Registration is fast, simple and free so join our community today.
Find a Green Building Pro
Browse Project Albums
View Product Guide
> Subject: Water Barrier
Prev
Next
Author
Messages
Oldest First
Newest First
OKBlocker
06/22/2001 9:53 PM
We have always used felt paper for a water barrier when using Dug-Fur for buck material.
I know Ian G. has used the "peal-and-stick" membrane for the same effect.
Do you think we could use a simple coating of Thompson's Water Repellant product to achieve the same effect?
I had a home owner ask and I didn't have the answer. What's your opinion on this guys?
seflpolyst
06/23/2001 9:25 AM
i would suggest to see if the applicable building code allows it.
Ian ICF Builders
06/23/2001 10:24 PM
No. Thompson's doesn't create a membrane..it is a "paint". The wood may still crack and check, leaving plenty of leeway for the beginnings of rot and mildew. Don't ignore the possibility of sweating behind the wood buck since the concrete should in theory maintain a smaller temperature fluctuation range. For the money, I'd go with the treated wood, vinyl, or wrap the untreated with a membrane.
markross
06/25/2001 5:26 PM
Why use wood? We don't. This seems to eliminate this problem.
Mark Ross
"Le Canuck"
Ian ICF Builders
06/25/2001 8:06 PM
We use wood when the customer says to use wood. We don't refuse to install ICF because the customer chooses wood bucks.
icfdesign
06/26/2001 12:50 AM
When using the peel n stick membrane, do you use any other adhesive or does the glue base on the peel n stick hold okay?
Ian ICF Builders
06/26/2001 8:04 AM
The membrane usually sticks by itself without the use of primer. We sometimes use staples along the edges (not in the center where the concrete would be).
markross
06/26/2001 3:37 PM
Ian:
We dont use wood, because we explain and show the customers how they can benifit both cost wise and quality wise by removing the wood from the equation.
Mark Ross
"Le Canuck"
Green Living
--<a href="http://discuss.greenoptions.com">Green Options</a>
> Water Barrier
Professionals Serving
Your Location:
Creative Panels
(Kingsburg, CA)
Amvic-Pacific
(Nevada City, CA)
Sierra SIPs
(San Andreas, CA)
Blue Lupin Developments
(Incline Village, NV)
Greenblock Worldwide Corp
(Cave Creek, AZ)
View More
GBT Project Albums:
Riggs Remodel
(Portland, OR)
magnolia remodel
(seattle, WA)
Cottage
(Rio Nido, CA)
Our new house
(Burt, MI)
The RANCH
(Williston, SC)
More Info
Copyright 2008 by BuildCentral, Inc.
Terms Of Use
Privacy Statement
