Hello,
I've lost/misplaced a website link about recently built home with radiant heating, system monitoring, design, construction, planning, and other information. I believe I saw it online sometime in Spring 2006. IIRC, it was a homeowner's own website, similar to
http://www.thegarsts.com/ , where they documented in text along with photos of what they did and why.
I believe the home had the following characteristics described on the website:
-new home, new land site
-built in a mountainous or hilly region (I seem to recall it being in the eastern US)
-radiant heating throughtout the home (I think it was 4 zones, maybe up to 6)
-mention of problems with radiant heating pipes getting too hot directly out of the heat source, near the distribution manifold, so they had to replace a section with copper until the water temperatures were low enough not to hurt the plastic piping (PEX ?)
-there was a photo of how all the radiant pipes came out of the floor together in the mechanical room to hook up to the distribution manifold
-monitoring mechanisms (e.g. many temperature sensors throughout the home, all hooked up to a computer or data logging system. The website had some graphs made from these sensor readings.)
-monitoring mechanism for electrical power consumption on each circuit in the house, to see where the actual loads were. This monitoring was done at the electrical panel, and I believe it was done with inductors around the lead coming out of the circuit breakers. There was a photo of this.
-a floorplan that was either cross-shaped (like a bandage-cross or the red-cross) or ~square/diamond-shaped. It wasn't a regular rectangular or L-shaped home. May have had a central room to which all the other rooms connected, rather than hallways.
-prefab concrete foundation walls (and it may have used prefab concrete panels for the basement slab too). There were photos of this going into place and notes about how fast/easy it was to do things this way. I think there were notes about sealing the seams between the prefab panels. There may have also been discussion of using 10 foot panels instead of 8 foot to get extra basement headroom at little additional cost.
-insulation under the basement floor
I do not recall the home having either solar PV or hot water. It may have had geothermal (GSHP), and may have been SIP construction above grade.
Around the time I found the home's information page, I was looking for a way to monitor/measure power consumption on each circuit in a home and I think that site had some limited information on this (as mentioned above).
Does anyone here remember seeing such a website? If so, do you have the website link for it, or remember any additional details about that place?
Thank you,
-Haudy Kazemi
