Radiant Heating
Good carpet choices over radiant?
Last Post 18 Sep 2008 04:26 PM by
Brock
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
jbrown84
17 Sep 2008 08:55 PM
Does anyone have any recommendations for a specific brand/line of carpeting that has low R-values? I'm going to use a 7/16" slab rubber pad over QuikTrak, and I'm hoping to find a nice carpet to use.
Jeff
BadgerBoilerMN
18 Sep 2008 07:01 AM
Carpet padding often has a higher R-value than the carpet. 1/4" commercial pad is most often specified. Your choices are dictated by the heat loss of your room and the designed heat output of your radiant floor panel.
jbrown84
18 Sep 2008 07:32 AM
I'm already using a rubber pad with a low R value (0.45), but I'd like to find some carpet options that are low (relatively speaking).
BadgerBoilerMN
18 Sep 2008 08:13 AM
This is not particularly low. I stay away from carpets over 1/2" thick and wool of any kind.
Again; Your choices are dictated by the heat loss of your room and the designed heat output of your radiant floor panel.
Brock
I would recommend something that is outside rated. They tend to be really thin and are meant to be used without a pad. I really would not put a pad of any kind under it; if you do you might as well not expect any heat from the floor, other then maybe a comfort heat and not any room heating.
Radiant Heating
Membership:
croccohvacusa
People Online:
