A question: If I keep an indirect water heater at, say, 125 degrees (just bear with me for a minute) and run 180 degree water through the tank's internal heat exchanger, what will the return temperature of the water generally be coming out of the water heater, on its way back to the boiler?
I'm sure that this is very dependent on the specifics of the tank, but in generalities, will the temperature be close to 125 degrees, or rather much higher than that?
Has anyone ever measured this sort of thing?
Jeff |
