Wire above or below tubing.
Last Post 07 Jan 2010 05:44 PM by ICFconstruction. 26 Replies.
07 Jan 2010 02:51 PM
soooo the fellow has zero room for insulation on top, door heights and headers in place... 2 inch slab topping pour w/ pipe, good thing is pipe is in most upper portion of slab, preferred by RPA guide lines.
The bottom of the plank is in conditioned space with height restrictions, I again would suggest 1 inch spray foam and sheet rock, R-6 or air gap 1 inch and Bubble foil bubble, R better than nothing....
Dan
Dan <br>BlueRidgeCompany.com
07 Jan 2010 02:59 PM
I will advise the customer to consider ceiling insulation.
07 Jan 2010 03:00 PM
1 inch of any real insulation would be a lot better than nothing.
radiantbarrierUser is Offline
07 Jan 2010 03:07 PM
Use Crete-Heat available in 1 or 2 Inch boards see at www.GreenInsulationProducts.com
07 Jan 2010 03:08 PM
you mean on top of the floor where he has no height available?
kicker_92User is Offline
07 Jan 2010 05:00 PM
- Check with your structural engineer before you put insulation under the topping layer on Spancrete. Sometimes the 2-3" topping is counted as part of the concrete design. It's probably won't affect you, but it's worth checking on first.
- Using rebar in place of wire mesh in might not meet ACI standard for minimum concrete cover distance.
- Regarding the high thermal mass, we had some good discussions here: http://www.greenbuildingtalk.com/Forums/tabid/53/forumid/12/postid/70675/view/topic/Default.aspx
Hope that helps...
The hollow core plank manufacture recommended a vapor barrier between their plank the topping.
People Online People Online: Visitors Visitors: 172 Members Members: 0 Total Total: 172
