Radiant Heating
Sizing an electric boiler
Last Post 09 Nov 2010 10:07 PM by
arcamm
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
arcamm
09 Nov 2010 06:54 PM
I'm about ready to buy a new electric boiler for my shop and I'm not sure what size would be best. I'm at 960 square feet with 4 200' loops in 4" of concrete. My design calculations indicate that I need about 20k btu's to meet my spec. I can get a 20k boiler or a 30K for close to the same price. Should I go for the extra overhead or keep it close to the calculations. The boilers are modulating. Any opinions would be appreciated.
NRT.Rob
09 Nov 2010 06:56 PM
it's hard to oversize an electric boiler, and more output will give you some better responsiveness. might as well go bigger in that case as long as minimum flow rates or electrical draw concerns are not a problem.
arcamm
09 Nov 2010 07:28 PM
Electric connections, no problem. Flow I'm not sure about. The boiler mfg lists the two boilers min flow at 2 gph for the 20K and 3.1 gpm for the 30K both at 15 psi. Mypanel piping is 3/4" through a 3/4" B&G air seperator and gurnfoss UP 15-42 SF pump into a 1" four port manifold.
Blueridgecompany.com
09 Nov 2010 08:40 PM
Have a look at our new electric stainless steel water heaters. They are about 1/2 cost of electric boiler and approved for space heating. minimal flow 1/2 gpm OK.
Dan
Dan <br>BlueRidgeCompany.com
arcamm
09 Nov 2010 09:02 PM
How do I find them? I looked at your website and only see the Thermolecs.
arcamm
I found them.
Radiant Heating
Membership:
croccohvacusa
People Online:
