Radiant Barrier versus rigid insulation between first floor and basement
Last Post 08 Feb 2013 09:48 AM by NRT.Rob. 2 Replies.
gatterUser is Offline
07 Feb 2013 03:39 PM
I have a suspended concrete slab with radiant tubing over a wood subfloor as a first floor in a single family residence in Climate Zone 5 in New York State. The basement is completely underground with 2" of rigid insulation on the outside walls. The only opening to the outside is a Bilco Door. The basement will be minimally heated. I originally had specified 1" white thermax (with a reflective side) for under the first floor joists but am now wondering whether a bubble reflective radiant barrier would work in this situation. The advantage is cost. Thanks....
sailawayrbUser is Offline
07 Feb 2013 08:54 PM
Siegenthaler recommends the following MINIMUM R-values:
Slab-on-Grade Floors: Rmin = 0.125(Ti - To)
Floors over heated spaces: R-11
Floors over partially heated basements: R-19
Floors over unheated spaces (e.g., crawl spaces or unheated basements): R-30
Sounds like you may be closer to being unheated than partially heated... Fiberglass batt is a fairly common way to accomplish Above-Floor or Below-Floor tube & plate system insulation. For a unheated space, you may want consider using a vapor permeable barrier under the batt to prevent trapping condensed moisture. To optimize the insulation economics, you might want to do a floor heat loss analysis with the objective of determining what R-value will keep the downward heat loss just under 10% of the upward heat gain required to meet your building/room heat loss analysis requirements for your climatic design conditions.
the answer to your question is no. reflective bubble insulation is never an acceptable replacement for real insulation.
People Online People Online: Visitors Visitors: 248 Members Members: 0 Total Total: 248
