Hi Everyone- Here is the history and question
Radiant floor on Main, basement and garage. The water feeding the floor is 105-110F and there are 3 loops coming of a main line (2") and a single pump feeding the 3 floor zones. The main level is on 1 zone and it goes thru an Erie zone valve then ino a 3/4 in copper pipe with 4 loops (pex type lines) out into the floor. The line coming off the main is 3/4 and then is coupled to the valve with a reducer bring it down to 1/2 ' thru the valve and then it utilizes an adapter to bring back up to 3/4 (then into the 4 loops). Why would it have been installed like this? I was wondering why the 3/4' line iwould not be connected to the valve and then to the copper with the 4 loops? The other 2 zones are connect this way too. I was wondering if I am getting in adequate volume of hot water out into the zones. Do I leave or should i adjust it. The main floor is the priority zone so when it is calling for heat the basement and garage are not receiving HW
I have attached a couple of valve set-up/piping pics
Thanks for your help
