Posted By kellytheaker on 13 Feb 2013 01:39 PM
Exellent discussion , i appreciate the efforts here . the footprint is 26 by 32 , i just came back and its just sitting at 50 degrees , sitting dormant/pump not circulating thermo set at 50 for am peak hydro . From the discussion i see that i may have a marginal chance of getting by with the cheapo water heater , but i do want better - what i mean is i would like to leave and set this down so as to not heave / frost protection but if i were to spend a month up there , i would like a response in two to three days to a livable floor 68* . what is a best value solution here - to heat this water better and at a reasonable cost . i will say im sucking hydro fast thats why the set back but i see its not the answer . is the answer a cheapo propane power tank or high end propane tank Polaris , air to air , electric boiler / propane boiler . all i want is to heat the floor well . not the rest of the cottage . i am leaving that chore to a pellet stove on the main floor heat and air condition will be an air to air unit . i thought i had this figured out . your discussions have been very enlightening .
Sorry to be away while all this dialog is going on. I agree with Dan about a modulating electric boiler. I've put in a few Thermo2000 units from Quebec which are pretty nice. I wouldn't go with anything propane because the cost is just too close to electricity here and then we have combustion to deal with. IMHO, the electric boiler and/or the ductless is the answer. with the electric boiler you can also get some DHW if desired or combine it with solar DHW.
Kelly, feel free to give me a call if you want to make any changes. My site is below. (first time I've done that on here, haha)
