OK, I'll bite
Every BTU you put into that building will ultimately escape. The greater the temp difference, the faster the heat transfers, of course any wind will speed the process. IF you are not using it full time, I think it is more efficient to set it at a temp that will meet the unoccupied needs. IE: nothing inside will freeze and the equipment and surfaces inside will stay above the dew point. If you use it at regular times, a timed/programmable thermostat could prep the space for your comfort, hours before the expected use time. It would then go back to the unoccupied temps.
Say for example: You set it at 50F during the week(might be able to go that low or lower, depends on your humidity levels). Lets say you typically get out there by 9AM on Saturday. You set the system to start heating the space about 1AM on Saturday morning so it is up to 68F by 9AM(just an example, have no idea how long your slab takes to get from 50-68F
) Say you normally stay out there till 3 or 4 PM. Since the slab will remain warm for quite a while, the thermostat could go back to the midweek/low set point probably around noon, so it is just starting to feel cooler about the time you are out the door anyway. For unanticipated use some sort of faster acting space heat to get to a comfort level quickly might be a good idea.
