How important are floor sensors?
Last Post 06 Feb 2017 09:30 PM by sailawayrb. 1 Replies.
georgebascoUser is Offline
03 Feb 2017 03:12 AM
I have no experience with radiant and am wondering how important floor sensors are to my particular setup?
- This is new construction in SF Bay Area.
- 3 floors including basement
- Basement and main floor have gypcrete slab, 2nd floor has tubing in plywood
- Well insulated
- 13 zones total
- HTP Phoenix with outside reset
The current plan is to use 13 thermostats, which will be 5' off the floor, without using any floor sensors.
Sheetrock is up, so getting a bit late to change this plan, but wondering if I'm going to regret not having the floor sensor. Or is it the case that in this relatively moderate climate and with the use of outdoor reset, that floor sensors aren't really needed to avoid over and under shoot?
The designer/installer is not concerned and this is how they do it here, but wanted to get any other feedback before it's too late.
Thanks for any input you might have..
sailawayrbUser is Offline
Floor temperature sensors can improve controllability, especially when you also use passive solar heating to warm your floors. However, in your mild climate area, I don’t think you will have any issue not having them. You sure do have a lot of zones. That can add significant expense to a HR system for very little benefit.
People Online People Online: Visitors Visitors: 85 Members Members: 0 Total Total: 85
