Possible net zero home with possible Geothermal?
Last Post 09 Apr 2007 08:47 AM by PanelCrafters. 1 Replies.
ronaldsauveUser is Offline
08 Apr 2007 10:40 PM
Hi everyone,
I would like some input regarding a project I may be building for a family in Salisbury, MA.  This family would like to go to net zero energy use if possible.  It is a Deltec round home, www.deltechomes.com built on a radiant frost protected shallow foundation slab.  The house is 2500 square feet, 10' walls rising to perhaps 16' in the center with a loft in the center.  We are looking at a slab insulated to about R30 underneath and up to the edge of the exterior walls, and R10-20 around the perimeter.  We will use closed cell sprayed polyurethane to R40 in the exterior walls, and R70-80 in the ceiling, so there will be little if any air infiltration.  Windows will have a u value of .08 to .12, depending on location, and shgc of around .55, again depending on location.  Windows are oriented mostly to true south with shading, so there will be a significant passive solar contribution.  In addition, there may be solar photovoltaics with net metering feeding back into the grid.
My question mainly deals with the HVAC:  I have received quotes of $40,000 for a 3 ton geothermal system with 2 drilled wells, including heat in the radiant slab, with 3-4 zones, a desuperheater to provide domestic hot water for 4 people, high velocity central air via a split system, and a heat recovery ventilator.  For heating alone, I show an approximate total heat loss of 8,000 - 10,000 btuh.  For 4 people, I believe the load would be a fair amount more for domestic hot water than for heat.  I know HVAC types propensity to oversize for safety's sake.  However, 3 tons worth?  And I know the northeast is higher priced, but $40,000 strikes me as a bit high.
What do you think?  I would appreciate any and all input.
Thanks much,
Ronald Sauve
Ronald,
You might ask this question over at Our Cool House. They are geothermal proponents.
Membership Membership: Latest New User Latest: croccohvacusa New Today New Today: 1 New Yesterday New Yesterday: 0 User Count Overall: 35027
People Online People Online: Visitors Visitors: 200 Members Members: 0 Total Total: 200
