Hi Kent,
Having spring water on your home building site could indicate that you have a good source for home use, but there are many questions I would want answered before betting on it as a reliable supply for geothermal use. As tuffluckdriller pointed out, you need to know at minimum the gpm flow rate and if it is constant or does it change at different times of the year. Other factors needed is the water content and what type of head pressure can it develop?
It sound like an interesting project. Please keep us posted on how things are going.
Regards,
