Geothermal Heat Pumps
central VA installers --lady needs help
Last Post 12 Nov 2008 11:50 AM by
Geothermalman
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
lisa6801
18 Jul 2008 10:31 AM
I am going to build in Madison Co (central VA). Charlettesville and Fredericksburg are the closest big towns. We can only go closed loop here and like everyone else cost is a factor. As I understand vertical drilling costs more (for one hole for well was $2K). I assume I would need approx. 5 vertical drops. Horizontal slinky is the less expensive from what I know. But any horizontal vice vertical is not as stable (consistent) in temperature because of being closer to the surface. The house is 2400sq main floor, with a full basement that will be particle finished (1800sq ft). Steep roof lines 12:12 pitch. I know insulation and building materials to be used are also a big factor for sizing any system. I am using the other forums to see pros/cons for SIPS/ICF vice wood. I am concerned like many here as to where our country is headed concerning energy. I have read about Climate Master, Water Furnace and Earthlink DX systems. I just am having a hard time finding some dealers/installers to talk to for comparison and the maintenance requirements after installation. I am not as savvy as so many of you are and would appreciate any help or advice. THX ahead lisa
WEL0058
12 Nov 2008 12:38 AM
Hi Lisa,
I live in the Haywood area of Madison and may be able to help you out. Last year I installed a ground source heat pump in my 2500sf Cape Cod home. The great thing building a new home is that you can reduce the heating and cooling loads by constructing a well insulated house. Has any one done a 'Manual J' to determine what the estimate heating / cooling load in order to determine the size of the heat pump?.
My email address is rgausman at vabb dot com.
joe.ami
12 Nov 2008 12:43 AM
Lisa, If you can't find local sources, contact manufacturers for a list of dealers. Make sure they do proper heat loads and keep us posted.
Good luck
Joe
Geothermalman
You can find accredited installers in your area at www.igshpa.okstate.edu
Membership:
croccohvacusa
People Online:
