Hello,
Perhaps I've used the wrong search terms so I apologize if I'm asking an old question. Located in southern CT and interetsed in converting to geothermal heat pump. Current system is oil fired forced hot air/central AC. Is it possible that existing duct work is amenable to heap pump conversion? I'm willing to continue to use oil to augment for very cold days. Can someone direct me to relevant links?
Thanks!
