Geothermal Heat Pumps
Where can I find disposable filters for a Hydron Module geothermal heat pump?
Last Post 30 Jul 2008 12:14 AM by
geodean
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
ksedro
28 Jul 2008 06:37 PM
I have a Hydron Module geothermal heat pump that takes a permanent but removable 30.125" x 32.5" x 1" filter.
I have two such filters that I swap when the one in use needs to be cleaned.
Soon I will have my wood floors sanded and 3 coats of poly-urethane applied. The floor finishers recommend
running the A/C (heat pump) rather than leaving windows open during the curing process. In order to protect
my permanent filters, I am trying to find disposable ones to use during that time period but have not managed
to find any that are large enough. Has anyone found disposable filters of that size?
Palace Geothermal
28 Jul 2008 08:22 PM
Hydron sells disposable filters
ksedro
29 Jul 2008 01:40 PM
How do you currently contact Hydron Module? The phone number that I have for them now reaches a different company (Intertech) and
www.hydronmodule.com now only shows an "under construction" page.
engineer
29 Jul 2008 02:48 PM
Filtersnow.com has disposable 30x30x1 which you might be able to adapt with some creativity
Palace Geothermal
Hydron was purchased by
[u]Enertech Mfg[/u]
So you have the right place.
Membership:
croccohvacusa
People Online:
