Open Loop Water Quality
Last Post 10 Aug 2008 12:57 AM by joe.ami. 1 Replies.
bgillettUser is Offline
09 Aug 2008 02:28 PM
What do you need in regards to water quality to have a open loop system with relatively low<!--[if gte mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> maintenance?
Background : I have a old (main house 100 years w/ several additions) 3200 sq ft house that has  an additional 1500 sq ft space for a indoor pool (16x32x5). I am redoing the ductwork for the main house and hopefully putting in a geo unit for the pool along w/ a humidification system. I have estimates for a 5 ton geo unit for the house and one for the pool room (to heat air and water). I have to go vertical w/ the systems so I need 10 bores. If I go w/ a traditional system that means about 28,000 for the pipes. This piping is cheapter for a dx system but the system costs more so there really isn't a savings. I am looking at possibly diong one or both of the systesm as open loop (I have a pond and a large ditch to which I can drain the water), but I am concerned with the maintaince of such a system. I also would mind using a return well for one of the systems. I am concerened that the open loop system will have way too much maintenance even though it could save me a hugh amount of money. My contractor says that I need good water. What does "good" water mean?
Ask your contractors to see the water quality standards.
Typical additional maintenance in MI;
flushing heat exchanger
replacing well pump every 8 ish years
occasionally having to go out in the pond in your waders and knock a hole in the ice or unplug the drain.
Upshots (again in MI);
cheaper to install
loosely 20% more heating capacity
Good Luck,
Joe
People Online People Online: Visitors Visitors: 260 Members Members: 0 Total Total: 260
